landikar написа:Са кой ша я слага..... Аз къф съм схванат в ръчичките
Много яка тая помпа бе.Сигурно ше духа яко
xixixixi .... и аз точно т'ва си мислех
Тука рано сутринта домъкнали куриерите един тежък и скъп кашон
75 turbodelta написа:е ти не си ли купи ве ламьо
j1v написа:75 turbodelta написа:е ти не си ли купи ве ламьо
Купих аз, ма отлетя по направление, сега ми трябва пак
killerbee написа:j1v написа:75 turbodelta написа:е ти не си ли купи ве ламьо
Имам една чисто нова но ми е запазена - колко пари даваш ?
rosen.kolarov написа:Ако някой ще прави поръчка да ме има и мен в
предвид с една бройка.
Stage 2 Boost Cooler™
This kit uses manifold boost pressure to determine when and how much fluid to inject. Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. More power and driveability is the result. It can be used on any forced induction engine: carbureted, fuel injected, turbocharged, positive displacement or centrifugal blowers. The most suitable are the centrifugal supercharged and turbocharged engines, as they build boost is a more progressive manner concerning water-methanol injection. The positive displacement blower engines will work, but it might take more work to dial in the delivery. For higher boost applications (over 25psi), the controller can be upgraded to our VC100 unit. Now with Lifetime Warranty - please see details.
Stage 2 MAF Boost Cooler™
This kit uses the 0 to 5 Volt output signal from the Mass Air Flow sensor on many fuel injected vehicles. This means that any vehicle with a MAF (with a 0-5V output signal) can use this kit, whether they are naturally aspirated or forced induction. If the application is forced induction, it can be used with very fast-spooling turbos, or positive displacement blowers. It is easier to set up with the positive displacement blowers with a MAF signal because it is more progressive in nature vs. the boost pressure signal on those applications. This allows for the most accurate injection possible over the widest range. The result is the most power and driveability possible. Now with Lifetime Warranty - please see details.
Boost Juice™
Boost Juice™ is Snow Performance’s proprietary mix of 49% methanol and 51% water. It is made in a controlled environment with special care to make sure the ratios are accurate to result in a high performance water-methanol fluid formulated for use in the Boost Cooler™ injection system. If Boost Juice™ is used exclusively in the Boost Cooler™ kit, Snow Performance offers a free lifetime warranty.
Solenoids should arrive here on or about the 26th september. It will take approximately 2-5 business days typical with ems shipping
j1v написа:Solenoids should arrive here on or about the 26th september. It will take approximately 2-5 business days typical with ems shipping
До края на септември може и да си имаме такива пръскалки
cosworth написа:j1v написа:Solenoids should arrive here on or about the 26th september. It will take approximately 2-5 business days typical with ems shipping
Какви поръчахте,може ли линк някакъв?
j1v написа:cosworth написа:j1v написа:Solenoids should arrive here on or about the 26th september. It will take approximately 2-5 business days typical with ems shipping
Същите като предните
http://www.aquastealth.com/index.asp?Pa ... &ProdID=88
Потребители разглеждащи този форум: 0 регистрирани и 10 госта
